- Mute
- Permalink
- Report
We are looking for API events triggered on selecting files in drawing view option. This will help us to find which file getting imported to drawing file.
steps:
Open the Inventor 2022 application.
Click New and select "Standard.dwg" option.
Click "Place Views" under the "Base"
Popup folder "Drawing view" will display and Click "Component".
Click "Open an Existing file" in File field and select already protected part file.
- Mute
- Permalink
- Report
Hi @prakash.muthu. Unfortunately, I believe the only drawing related events that we have direct access to through Inventor's API are the DrawingEvents.OnRetrieveDimensions Event, and the DrawingViewEvents.OnViewUpdate Event. And I believe that second one is the same one that you see listed within the Event Triggers dialog, named 'Drawing View Change'.
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hi @prakash.muthu. I do not think it is possible for us (regular Inventor users) to define new events for the DrawingView Object. Those Events are built into Inventor's API (application programming interface) for that object by Autodesk. There is a block of code somewhere within their program files which creates the Class that is used to define these DrawingView objects. Within that Class block of code is where all of its Methods (Sub & Function routines), Properties, & Events are defined/created. Either Autodesk would have to update their Class block of code to define/create new Events for it, or we would have to create our own new Class block of code to represent our own version slightly different version of the DrawingView object, in which we define new Events for it. But then you would have to know how to back-up those events, so they can be used, and you would have to define your DrawingView object as being one of your different Type of object, so you could access its Events. It's pretty complicated.
Wesley Crihfield
- Mute
- Permalink
- Report
Hi Prakash,
I'm assuming that from your drawing you cant just fire an external rule Before Document Save, that would get the model of the last view on the active sheet? E.g.
Dim inventorApp As Application = ThisApplication ' Check that the active edit document is a drawing document If Not inventorApp.ActiveDocument.DocumentType = kDrawingDocumentObject Then Logger.Info("Not Drawing Document") Exit Sub End If drawingDoc = inventorApp.ActiveDocument ' Get the active sheet as thats where the view is being placed Dim drgActiveSheet As Sheet = drawingDoc.ActiveSheet ' Set reference to the views on the sheet Dim activeSheetDrawingViews As DrawingViews = drgActiveSheet.DrawingViews ' Get the last view created Dim newestView As DrawingView = activeSheetDrawingViews.Item(activeSheetDrawingViews.Count) ' Get the document that this view references docViewModel = newestView.ReferencedDocumentDescriptor.ReferencedDocument ' Get the file name, this is hopefully what you are after and you can then write this to an iProperty or text file etc... ' This will obviously get updated each time a new view is placed, and override the previous value Dim viewModelName As String = docViewModel.FullDocumentName MsgBox("New View model: " & viewModelName)
Assuming that you can't, then this next code may be handy. Please test it thoroughly before using it on production drawings.
' After the create view command has finished it gets the last created view's model filename ' Add this rule to your drawing template as an external rule, on the following rule events New Document & After Open Document Class ThisRule Private WithEvents appEvents As ApplicationEvents Private WithEvents docEvents As DocumentEvents Public drawingDoc As DrawingDocument = Nothing Public FDName As String Public beforeTimingEnum As EventTimingEnum = EventTimingEnum.kBefore Public afterTimingEnum As EventTimingEnum = EventTimingEnum.kAfter Public contxt As NameValueMap Public handling As HandlingCodeEnum Public reasonForChange As CommandTypesEnum Public previousCMDName As String = Nothing Public previousPreviousCMDName As String = Nothing Sub Main Dim inventorApp As Application = ThisApplication ' Check that the active edit document is a drawing document If Not inventorApp.ActiveDocument.DocumentType = kDrawingDocumentObject Then Logger.Info("Not Drawing Document") Exit Sub End If drawingDoc = inventorApp.ActiveDocument If drawingDoc Is Nothing Then Logger.Error("$$$drawingDoc is nothing") appEvents = inventorApp.ApplicationEvents docEvents = drawingDoc.DocumentEvents FDName = drawingDoc.FullDocumentName End Sub Sub appEvents_OnCloseDocument(drawingDoc As Document, FDName As String, beforeTimingEnum As EventTimingEnum, contxt As NameValueMap, _ ByRef handling As HandlingCodeEnum) Handles appEvents.OnCloseDocument Logger.Info("Closing Doc") RemoveHandler docEvents.OnChange, AddressOf docEvents_OnChange RemoveHandler appEvents.OnCloseDocument, AddressOf appEvents_OnCloseDocument End Sub Sub docEvents_OnChange(reasonForChange As CommandTypesEnum, afterTimingEnum As EventTimingEnum, _ contxt As NameValueMap, ByRef handling As HandlingCodeEnum) Handles docEvents.OnChange Dim CommandName As String = contxt.Value("DisplayName") Logger.Info("1CommandName: " & CommandName) Logger.Info("2previousCMDName: " & previousCMDName) ' Only run after these three commands have been run in this sequence, otherwise we can end up in a loop. ' This seems to be the sequence of commands that happen when at the tail end of view creation If CommandName = "Edit View Properties" And previousCMDName = "Edit View Properties" And previousPreviousCMDName = "Create Drawing View" Then ' Get the active sheet as thats where the view is being placed Dim drgActiveSheet As Sheet = drawingDoc.ActiveSheet ' Set reference to the views on the sheet Dim activeSheetDrawingViews As DrawingViews = drgActiveSheet.DrawingViews ' Get the last view created Dim newestView As DrawingView = activeSheetDrawingViews.Item(activeSheetDrawingViews.Count) ' Get the document that this view references docViewModel = newestView.ReferencedDocumentDescriptor.ReferencedDocument ' Get the file name, this is hopefully what you are after and you can then write this to an iProperty or text file etc... ' This will obviously get updated each time a new view is placed, and override the previous value Dim viewModelName As String = docViewModel.FullDocumentName MsgBox("New View model: " & viewModelName) Logger.Info("New View model: " & viewModelName) End If previousPreviousCMDName = previousCMDName previousCMDName = CommandName End Sub End Class ']j
Cheers,
James
