WCrihfield
in reply to: Lars_Greft
Hi @Lars_Greft.  I do not have Vault yet, though we have talked about it several times, and may be getting it soon.  I wander though what would happen in situations were your assembly may have multiple instances of components that represent the same source document, when 1 or more of them may be suppressed, and 1 or more of them may not be suppressed.  If you are writing one of those terms to the document, wouldn't that info be incorrect or misleading?  I don't know, just a thought that popped into my mind.  One fairly new thing that comes to mind is the 'instance properties', which allows you to set custom iProperty values to each instance of a component in an assembly, even if they represent the same base document.  But I don't know if Vault can work with those 'instance' properties, so I don't know if their use would help or not.
Wesley Crihfield
(Not an Autodesk Employee)
