Here is commented example how to get all drawing curve segments of all instances of part.
'Select drawing curve of the part
Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick drawing curve")
'Get assembly occurrene which the selected DrawingCurveSegment belongs to
Dim curveSegment As DrawingCurveSegment = pick
Dim parentCurve As DrawingCurve = curveSegment.Parent
Dim someProxy = parentCurve.ModelGeometry
Dim partOcc As ComponentOccurrence = someProxy.ContainingOccurrence
'Get AssemblyDocument referenced by DrawingView
Dim drawingView As DrawingView = drawingCurve.Parent
Dim viewAsm As AssemblyDocument = drawingView.ReferencedDocumentDescriptor.ReferencedDocument
'Get all occurrences which has the same ComponentDefinition
Dim allInstancesOfPartOcc As ComponentOccurrencesEnumerator = _
viewAsm.ComponentDefinition.Occurrences.AllLeafOccurrences(partOcc.Definition)
'Get all DrawingCurveSegments of each part instance
'and convert them to ObjectCollection
Dim occDrawingCurvesCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
For Each occ As ComponentOccurrence In allInstancesOfPartOcc
	Dim occDrawingCurves As DrawingCurvesEnumerator = drawingView.DrawingCurves(occ)
	For Each occDrawingCurve As DrawingCurve In occDrawingCurves
		For Each occDrawingCurveSegment As DrawingCurveSegment In occDrawingCurve.Segments
			occDrawingCurvesCollection.Add(occDrawingCurveSegment)
		Next
	Next
Next
'Do something useful with occDrawingCurvesCollection
'Select all DrawingCurveSegments of the occ in the DrawingView
Dim drawingDoc As DrawingDocument = drawingView.Parent.Parent
drawingDoc.SelectSet.SelectMultiple(occDrawingCurvesCollection)
