WCrihfield
in reply to: Lars_Greft
Hi @Lars_Greft.  One thing that comes to mind when I see the two terms you are wanting to write to these documents is the BOMStructure property of the AssemblyComponentDefinition, PartComponentDefinition, ComponentDefinition, and the ComponentOccurrence objects, which uses the BOMStructureEnum variations as its value.  Many folks use that for setting whether the model is to be used for 'Normal' purposes, 'Reference', 'Purchased', 'Phantom', 'Inseperable', and such.  The BOM also uses that value when determining some things, so it can be very useful to take advantage of, if you are not already.  Manually, within a model type document, you can open the Document Settings (on the Tools tab > Options panel), and the 'Bill of Materials' tab within that dialog to set its value.
Wesley Crihfield
(Not an Autodesk Employee)
