You can extend your code like this
Some variables have been renamed for better readability.
Sub main()
    Dim templateFile = "" ' "Template.idw"
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    'Main assembly drawing
    CreteAssemblyDrawing(oAsmDoc, templateFile)
    'Drawings for sub-assemblies
    For Each doc As Document In oAsmDoc.AllReferencedDocuments
        If doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
        CreteAssemblyDrawing(doc, templateFile)
    Next
End Sub
Private Sub CreteAssemblyDrawing(oAsmDoc As _Document, templateFile As String)
    'Create and activate new drawing
    Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(
        DocumentTypeEnum.kDrawingDocumentObject,
        templateFile,
        True
    oDrawingDoc.Activate()
    'Create sheets
    Dim numberOfSheets = 2
    For sheetNumber As Integer = 1 To numberOfSheets
        If oDrawingDoc.Sheets.Count < sheetNumber Then
            Dim size As DrawingSheetSizeEnum = DrawingSheetSizeEnum.kA4DrawingSheetSize
            Dim orientation = PageOrientationTypeEnum.kPortraitPageOrientation
            Dim oSheet = oDrawingDoc.Sheets.Add(size, orientation)
            'TODO: Add title block, border etc.
        End If
    Next
    'Get first sheet
    Dim firstSheet As Sheet = oDrawingDoc.Sheets.Item(1)
    CreateFirstSheet(firstSheet, oAsmDoc)
    'Get second sheet
    Dim secondSheet As Sheet = oDrawingDoc.Sheets.Item(2)
    CreateSecondSheet(secondSheet, oAsmDoc)
    'And so on...
End Sub
Private Sub CreateFirstSheet(oSheet As Sheet, oAsmDoc As _Document)
    'Implement you own layout for first sheet
    'Create isometric view
    Dim isoViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 1.25,
        oSheet.Height / 3)
    Dim isoView = oSheet.DrawingViews.AddBaseView(
        oAsmDoc,
        isoViewPosition,
        1 / 30,
        ViewOrientationTypeEnum.kIsoTopRightViewOrientation,
        DrawingViewStyleEnum.kShadedDrawingViewStyle
    'Create frontView
    Dim frontViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 4,
        oSheet.Height / 1.25)
    Dim frontView = oSheet.DrawingViews.AddBaseView(
        oAsmDoc,
        frontViewPosition,
        1 / 20,
        ViewOrientationTypeEnum.kFrontViewOrientation,
        DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle
    'NOT USED
    'Dim V3Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(frontView.Center.X - 10, frontView.Center.Y)
    'Get top view initial position
    'Dim topViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(frontView.Center.X, frontView.Center.Y + 10)
    Dim topViewPosition As Point2d = frontView.Center.Copy()
    topViewPosition.Y += 10
    'Create top (projected) view
    Dim topView As DrawingView = oSheet.DrawingViews.AddProjectedView(
        frontView,
        topViewPosition,
        DrawingViewStyleEnum.kFromBaseDrawingViewStyle
    'Move top view to final position
    Dim oSep As Double = 1 'NOT DECLARED
    topViewPosition.Y = frontView.Center.Y - frontView.Height / 2 - oSep - topView.Height / 2
    topView.Position = topViewPosition
End Sub
Private Sub CreateSecondSheet(oSheet As Sheet, oAsmDoc As _Document)
    'TODO: Implement you own layout for second sheet
    'I reuse the same code for first sheet
    CreateFirstSheet(oSheet, oAsmDoc)
End Sub
