Sorry,
I use thise code for automatic drawing sheet bay sheet and only open assambly:
Sub main
	'Dim oAsmDoc As Document = ThisDoc.Document
	Dim oAsmDoc As _Document = ThisApplication.ActiveDocument
	templateFile = "Template.idw"
	Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
	oDrawingDoc.Activate()
	Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
	Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width/4, oSheet.Height/1.25)
	Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width/1.25, oSheet.Height/3)
	Dim oView As DrawingView
	oView = oSheet.DrawingViews.AddBaseView(oAsmDoc,  oPoint2,  1/30,  ViewOrientationTypeEnum.kIsoTopRightViewOrientation,DrawingViewStyleEnum.kShadedDrawingViewStyle	)
	'oView.RotateByAngle((PI / 180), True)
	oView = oSheet.DrawingViews.AddBaseView(oAsmDoc, oPoint1, 1 / 20, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, )
	Dim V2Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y + 10)
	Dim V3Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X - 10, oView.Center.Y)
	Dim oView2 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, V2Point2D, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	oView2.Position = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X,  oView.Center.Y - oView.Height / 2 - oSep - oView2.Height / 2)
End Sub
, and i lyke to modif for multi sheet drawing and all subassambly with part number.
Thanks.
