At first, I could not replicate the error. But I think I found the problem. The devil seems to be in the details. I could reproduce the problem with the following steps:
  • Start Inventor.
  • Load the addin with the add-in manager.
    • Notice that the addin loads as expected!
  • Unload the addin with the add-in manager.
    • Notice that the addin is not really unloaded. The button is still on the ribbon and still works.
    • Now we get the exception!
The problem is that the ButtonDefinition and CommandControl are not unloaded and therefore they can't be recreated. For normal users, this should not be a problem because they rarely reload addins. And I don't know what your use case is but you can solve the problem by unloading the ButtonDefinition and CommandControl explicitly on deactivation of the addin.
Cahnge the StandardAddInServer.Deactivate() to look like this:
Public Sub Deactivate() Implements ApplicationAddInServer.Deactivate
    _myButton.Unload()
    _myButton = Nothing
End Sub
 And your class MyButton should look like this.
Imports Inventor
Public Class MyButton
    Private _inventor As Inventor.Application
    Private _settingsButton As ButtonDefinition
    Private _control As CommandControl
    Public Sub New(inventor As Inventor.Application)
        _inventor = inventor
        SetupButtonDefinition()
        AddButtonDefinitionToRibbon()
    End Sub
    Public Sub Unload()
        _control.Delete()
        _control = Nothing
        _settingsButton.Delete()
        _settingsButton = Nothing
    End Sub
    Private Sub SetupButtonDefinition()
        Dim conDefs As ControlDefinitions = _inventor.CommandManager.ControlDefinitions
        _settingsButton = conDefs.AddButtonDefinition(
            "MyButton DisplayName",
            "MyButton InternalName",
            CommandTypesEnum.kEditMaskCmdType,
            Guid.NewGuid().ToString(),
            "MyButton DescriptionText",
            "MyButton ToolTipText",)
        AddHandler _settingsButton.OnExecute, AddressOf MyButton_OnExecute
        _settingsButton.StandardIcon = PictureDispConverter.ToIPictureDisp(My.Resources.MyImage16x16)
        _settingsButton.LargeIcon = PictureDispConverter.ToIPictureDisp(My.Resources.MyImage32x32)
    End Sub
    Private Sub AddButtonDefinitionToRibbon()
        Dim ribbon As Ribbon = _inventor.UserInterfaceManager.Ribbons.Item("Assembly")
        Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Item("id_TabManage")
        Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Item("iLogic.RibbonPanel")
        _control = ribbonPanel.CommandControls.AddButton(_settingsButton)
    End Sub
    Private Sub MyButton_OnExecute(Context As NameValueMap)
        Try
            Dim rule As New ThisRule()
            rule.ThisApplication = _inventor
            rule.Main()
        Catch ex As Exception
            MsgBox("Something went wrong while runing rule. Message: " & ex.Message)
        End Try
    End Sub
End Class
you can view the changes here:
https://github.com/hjalte79/MyILogicAddin/commit/6b566804dbe8ae50048f85f92b968192705245d8
Jelte de Jong
Blog: hjalte.nl - github.com
