Maxim-CADman77
in reply to: jjstr8
@jjstr8
Exception occurs in button class (please don't laugh loud on my debug MsgBox-es):
Imports Inventor
Public Class MyButton
    Private _inventor As Application
    Private _settingsButton As ButtonDefinition
    Public Sub New(inventor As Application)
        MsgBox("00")
        _inventor = inventor
        MsgBox("10")
        SetupButtonDefinition()
        MsgBox("20")
        AddButtonDefinitionToRibbon()
        MsgBox("30")
    End Sub
    Private Sub SetupButtonDefinition()
        MsgBox("11")
        Dim conDefs As ControlDefinitions = _inventor.CommandManager.ControlDefinitions
        _settingsButton = conDefs.AddButtonDefinition(
            "CJS Cutter",
            "CJSC_VB",
            CommandTypesEnum.kEditMaskCmdType,
            Guid.NewGuid().ToString(),
            "Automatic creation of halved-style paired slots for overlapping perpendicular flat bodies of Multi-Body Part.",
            "Cross-Joint Slot Cutter (VB)")
        MsgBox("12")
        AddHandler _settingsButton.OnExecute, AddressOf MyButton_OnExecute
        MsgBox("13")
        _settingsButton.StandardIcon = PictureDispConverter.ToIPictureDisp(My.Resources.CJSC_icon_16)
        MsgBox("14")
        _settingsButton.LargeIcon = PictureDispConverter.ToIPictureDisp(My.Resources.CJSC_icon_32)
        MsgBox("15")
    End Sub
    Private Sub AddButtonDefinitionToRibbon()
        MsgBox("21")
        Dim ribbon As Ribbon = _inventor.UserInterfaceManager.Ribbons.Item("Part")
        MsgBox("22")
        Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Item("id_TabModel")
        MsgBox("23")
        Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Item("Part.id_TabModel.UserCommands")
        MsgBox("24")
        ribbonPanel.CommandControls.AddButton(_settingsButton)
        MsgBox("25")
    End Sub
    Private Sub MyButton_OnExecute(Context As NameValueMap)
        Try
            Dim rule As New ThisRule()
            rule.ThisApplication = _inventor
            rule.Main()
        Catch ex As Exception
            MsgBox("Something went wrong while running rule. Message: " & ex.Message)
        End Try
    End Sub
End Class
... but it seems there are two different cases:
Case #1 (SOLVED). If the Add-In is loading with "Load Automatically" option then exception occurs on:
Case #2. If Add-In is loading manually from Add-In Manager then exception occurs on:
_settingsButton = conDefs.AddButtonDefinition( ...
... and it seems not related to my values (reproducible on the code from the article)
Please vote for Inventor-Idea Text Search within Option Names
