@Darkforce_the_ilogic_guy wrote:
.....as long as I have not checked in. I can just delete the locale file.. and recreate it after making the change in the Content Center....
Check out the file from Vault & then you should be able to do the same workflow as long as the file name stays the same.
Ex: 1234.ipt is checked into Vault. 1234.ipt is checked out of Vault. The local file of 1234.ipt is deleted & recreated from scratch. 1234.ipt can be checked back into Vault without error as long as it is in the same file location with the same file name.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
