tyler.warner
in reply to: steveh3
@steveh3 I made some adjustments to the Excel sheet to do some of the calculations for you. The form in the part file now updates to the available options, by selecting your two parameter inputs at the top of the form & then clicking the update button. The only thing that you will need to change to test this out is:
DiscSelector.ipt --> ParametersChosen Rule --> oExcelFileName (the correct path to your excel file)
See if this is what you're looking for.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
