WCrihfield
in reply to: steveh3
Hi @steveh3.  I didn't have time to create a complete solution for you today, but I did create something to get you further along in your project.  It is difficult to get data from Excel in a 2-dimensional array using iLogic's built-in GoExcel functions, so I opted for digging into Excel's API for this one.  This will get the Excel data to a 2D array for you.  Then just to show you that it worked, I included a message at the end that shows you the values across the last line of data.  The comparisons and filtering can be added later.
This is the code I have for you right now.
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports Microsoft.Office.Interop.Excel
Sub Main
	Dim oFile As String = "C:\Temp\Wheel_database.xlsx"
	Dim oSheet As String = "FormedPlates"
	'start a new instance of Excel
	Dim oExcel As New Excel.Application
	oExcel.DisplayAlerts = False
	oExcel.Visible = True
	Dim oWB As Workbook = oExcel.Workbooks.Open(oFile)
	Dim oWS As Worksheet = oWB.Sheets.Item(oSheet)
	'specify the range of cells in that sheet you want to read into memory
	Dim oRange As Range = oWS.Range("A1:D32")
	'create 2-dimensional array of Object, and set the range's values into it
	Dim oArray(, ) As Object = oRange.Value
	'read from an array by specifying row, then column, both starting with 1
	Dim oLastRowData As String
	oLastRowData = oArray(32, 1).ToString
	oLastRowData = oLastRowData & " <> " & oArray(32, 2).ToString
	oLastRowData = oLastRowData & " <> " & oArray(32, 3).ToString
	oLastRowData = oLastRowData & " <> " & oArray(32, 4).ToString
	MsgBox("oLastRowData = " & oLastRowData,,"")
	oWS = Nothing
	oWB.Close
	oWB = Nothing
	'oExcel.Quit
	oExcel = Nothing
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
