steveh3
273 Views, 3 Replies
Getting data from a spreadsheet with 2 dimension array
Hello Gang...
I have a spreadsheet which has two dimensions OD and BC.
For the DimC, I would like to gather all the rows where OD is greater than or equal to the DimC value chosen in the form (grey hi-lited cells).
Then also do the same for the BC. Select all rows where BC is greater than or equal to MaxBC (yellow hi-lited cells).
Then the result for AvailableDiscs would be the intersection of the two sets (green hi-lited). This would then show up in the form as what would be available to chose.
I have the form and spreadsheet set up, but I can't figure out how to dynamically update the Listing of AvailableDiscs.
I'm assuming this is possible?
I have included the .ipt and spreadsheet as attachments.
Thanks in advance,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
