- Mute
- Permalink
- Report
Changing iProperties of an iPart from an Assembly
Is it possible to change the iProperties of the parent iPart from an assembly? I found and modified this rule but it doesn't work very well with iParts. Is there a way to make this work with iParts?
- Mute
- Permalink
- Report
How are you using the factory file (Parent iPart), In a library? Or are you using the factory file only? What would the reason be behind changing factory file by code? If in the library setting, that is a manual operation done in the factory file table.
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
We create parts out of lengths of extrusions. Each member is a different length with a different configuration of holes and cuts. Each part is then put into an assembly with parts from different extrusions and iPart factories. Our customer has come back and asked if we can add the die profile number to the information that we give them. With regular parts, we can edit this information in the BOM, but with iParts you can't edit the information in the BOM. So we are looking for a way to add this information without opening each individual iPart factory and manually changing it. Hopefully this makes sense.
- Mute
- Permalink
- Report
It can be done but updating the factory file can be difficult as you need to work out where you are in the table via rows and columns and then update the generated file.
A few more questions.
1. Is the factory file in a library folder meaning it’s read only and needs a project file change to edit? Or is it in the workspace/ a writeable path?
Here is a link to get you started.
It is written in VBA and access directly the table.
https://adndevblog.typepad.com/manufacturing/2013/02/manipulate-rows-and-columns-of-ipart-1.html
Regards
Alan
- Mute
- Permalink
- Report
Here is a rule that seems to work consistently. This rule will update the factory iPart located in either the workspace of location that is not a library and where the factory iPart is writeable.
To add more iProperties just add another inputbox, sub routine call and adjust the column title requiring editing.
ChangeFactoryValue(oPartDoc, "Part Number", PartNo)'Adjust string value "Part Number"
Working Rule:
Sub Main Dim PartNo As String = InputBox("Prompt", "Part Number", "Default Entry") Dim Desc As String = InputBox("Prompt", "Description", "Default Entry") Dim oAssyDoc As AssemblyDocument = ThisDoc.Document Dim oPartoOcc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select Part") If oPartoOcc Is Nothing Then Exit Sub ElseIf oPartoOcc.Definition.Type = ObjectTypeEnum.kPartComponentDefinitionObject Dim oPartDoc As PartDocument = oPartoOcc.Definition.Document 'Adjust the inputs to the factory table ChangeFactoryValue(oPartDoc, "Part Number", PartNo)'Adjust string value "Part Number" ChangeFactoryValue(oPartDoc, "Description", Desc) Else MsgBox("Not a Part Exiting.", vbExclamation, "Occurrence Check") Exit Sub End If oAssyDoc.Update End Sub Sub ChangeFactoryValue(oPartDoc As PartDocument, ColHeader As String, CellValue As String) Dim oCompDef As PartComponentDefinition Dim oFactoryDoc As PartDocument If oPartDoc.ReferencedDocumentDescriptors.Count = 0 Then MsgBox("Chosen document is not a factory.", vbExclamation,"Document Check") Exit Sub Else oCompDef = oPartDoc.ReferencedDocumentDescriptors(1).ReferencedDocument.ComponentDefinition If oCompDef.IsiPartFactory = False Then MsgBox ("Chosen document is not a factory. factory check", vbExclamation,"Document Check") Exit Sub ElseIf oCompDef.IsiPartFactory = True oFactoryDoc = oPartDoc.ReferencedDocumentDescriptors(1).ReferencedDocument End If End If Dim sFileName As String = IO.Path.GetFileNameWithoutExtension(oPartDoc.FullFileName) Dim oFactory As iPartFactory = oCompDef.iPartFactory Dim iRow As Integer For iRow = 1 To oFactory.TableRows.Count If oFactory.FileNameColumn.Item(iRow).Value = sFileName Then Exit For End If Next For Each oEachCol As iPartTableColumn In oFactory.TableColumns Try If oEachCol.DisplayHeading = ColHeader Then Try oEachCol.Item(iRow).Value = CellValue Catch MsgBox ("Problem updating factory, It could be in a Library and Read Only", vbExclamation,"Document Check") End Try End If Catch End Try Next oFactoryDoc.Rebuild End Sub
Regards
Alan
