tomislav.peran
687 Views, 4 Replies
Delete body
This is probably a bit exotic question but is it possible to delete a body inside a part environment with iLogic code?
I generate this body from another assembly, then I delete it after I finish extracting parameters from Region properties. That means that every time I repeat the process the name of the body changes (Base1 then Base 2, then Base 3...etc).
If somebody knows how to delete this body please let me know.
Tom
