09-15-2022
03:39 PM
- Mute
- Permalink
- Report
09-15-2022
03:39 PM
Try this one & see if you're still getting the error. I changed the name & path variables slightly because I wasn't sure what was being entered into the Sub. This will overwrite the file in the specified folder if it already exists, so you'd have to write a check if you don't want that to be the case.
Public Sub CreateStandardPart(x_length As Double, y_length As Double, z_length As Double, loc As String, oPath As String)
MsgBox("here with x length = " & x_length)
Dim oFileName As String = "Save Melter Model.ipt"
Dim oFilePath As String = "C:\Temp\"
'Create a new part with your desired part template
'Dim oApp As Class = g_inventorApplication
Dim oProjectMgr As DesignProjectManager = g_inventorApplication.DesignProjectManager
Dim oProject As DesignProject = oProjectMgr.ActiveDesignProject
Dim oTemplatesPath As String = oProject.TemplatesPath
Dim oDoc As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "/English/OC Standard.ipt", True)
Try
oDoc.SaveAs(oFilePath + oFileName, False)
Catch ex As Exception
MsgBox("Copy didn't work!.... see error message below:" & vbNewLine & ex.Message)
Exit Sub
End Try
End Sub
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
