cstephens58F4Q
in reply to: WCrihfield
@WCrihfield again on this section of code. Any reason you could see why I would be getting the attached error in this line of code: oDoc.SaveFileAs(oPath & loc)
error:
System.MissingMemberException: 'Public member 'SaveFileAs' on type '_DocumentClass' not found.'
Issue area:
    Public Sub CreateStandardPart(x_length As Double, y_length As Double, z_length As Double, loc As String, oPath As String)
        MsgBox("here with x length = " & x_length)
        'Create a new part with your desired part template
        'Dim oApp As Class = g_inventorApplication
        Dim oProjectMgr As DesignProjectManager = g_inventorApplication.DesignProjectManager
        Dim oProject As DesignProject
        oProject = oProjectMgr.ActiveDesignProject
        Dim oTemplatesPath As String
        oTemplatesPath = oProject.TemplatesPath
        Dim oDoc As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "/English/OC Standard.ipt", True)
        oDoc.Activate()
    End Sub
Here is how I am calling out oPath:
SaveFileDialog1.Filter = "Assembly|*.iam"
        SaveFileDialog1.InitialDirectory = "C:\Temp"
        SaveFileDialog1.Title = "Save Melter Model"
        SaveFileDialog1.ShowDialog()
        If SaveFileDialog1.FileName IsNot "" Then
            SaveFileDialog1.OpenFile()
            oFile = SaveFileDialog1.FileName
        End If
        ''Sets directory for future use
        Dim oPath_ As String = oFile
        Dim oPat As Integer = InStrRev(oPath_, "\")
        Dim oPath As String = Mid(oPath_, 1, oPat)
