cstephens58F4Q
351 Views, 6 Replies
Issue creating a new part file in API
Im sure im overlooking something small but I am trying to get a part file created before I edit it with passed variables. The issue Im having is the line below is giving me the error "Error BC30469 Reference to a non-shared member requires an object reference. "
Dim oDoc As PartDocument = Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "standard.ipt", False)
Below is this full portion of code:
Public Sub CreateStandardPart(x_length As Double, y_length As Double, z_length As Double, loc As String, oPath As String)
        'Create a new part with your desired part template
        Dim oProjectMgr As DesignProjectManager
        Dim oProject As DesignProject
        oProject = oProjectMgr.ActiveDesignProject
        Dim oTemplatesPath As String
        oTemplatesPath = oProject.TemplatesPath
        oDoc.OpenFile()
        oDoc.SaveAs(loc & oPath, True)
        oDoc.Close(False)
    End Sub
 Let me know if you have any ideas. Thanks
