09-12-2022
08:36 AM
- Mute
- Permalink
- Report
09-12-2022
08:36 AM
Hi @vpeuvion. I think I have worked out a way that you can use. Check out the example below, and see if that works for you.
Sub Main
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oSMCD As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
Dim oBendsEnum As BendsEnumerator = oSMCD.Bends
Dim oSMF As SheetMetalFeatures = oSMCD.Features
Dim oCM As CommandManager = ThisApplication.CommandManager
'get stationary face
Dim oFace As Face = oCM.Pick(SelectionFilterEnum.kPartFaceFilter,"Sélectionner la face de référence")
If IsNothing(oFace) Then Return
'get the bend to unfold
Dim oBendFace As Face = oCM.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face Of Bend")
If IsNothing(oBendFace) Then Return
Dim oBend As Bend
Try
'you can get a specific Bend by specifying either Index # or Face object belonging to a Bend
oBend = oBendsEnum.Item(oBendFace)
Catch
MsgBox("Selected Face did not belong to a Bend.", vbExcamation, "")
Return
End Try
'add the Bend to our oBends collection
Dim oBends As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
oBends.Add(oBend)
'create the UnfoldFeatrue for just that one Bend
Dim oUnFoldFeat As UnfoldFeature
If oBend.IsFlat = False Then
'MsgBox("Bend is not flat, so we are able to unfold it.",,"")
oUnFoldFeat = oSMF.UnfoldFeatures.Add(oFace, oBends)
Else
'MsgBox("Bend is already flat, so we are NOT able to unfold it.",,"")
End If
oPartDoc.Update
MsgBox("Now to refold the bend.",,"")
're-set contents of oBends using UnfoldFeature we created above
oBends.Clear
For Each oB In oUnFoldFeat.Bends
oBends.Add(oB)
Next
oSMF.RefoldFeatures.Add(oFace, oBends)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
