Can you get some log message /messagebox installed for each of the parameters to see why it fails on those values? I assume the ilogic rule is intending to change them and the model is erroring out because they are not possible values. Without the model or the rule this is a difficult question to answer. This is an internal rule by the way the parameter is presented. Therfore the parameter
Door_Height is in the assembly and driving the part parameter correct?
Regards
Alan
