A.Acheson
in reply to: mgeeW7SQV
Unfortunately I have not much experience with updating styles. It sounds like if you need to run the rule twice it is only doing a partial update. This post here describes in more detail how to set this up without using the control definition update style. In your case if your not comfortable with the longer method discussed there you may be able to place the update style in a sub routine and just call it twice in the same rule. If you need more assistance just post the code your working with and hopefully someone can spot the required changes.
Regards
Alan
