jjstr8
in reply to: TGibson7A8HD
@TGibson7A8HD   I made an add-in for batch PDF creation several years ago.  The PDF translator add-in always created a PDF in the IDW's sheet size.  I ended up using the Microsoft Print to PDF driver and doing a regular print of the IDW.  This should be pretty straightforward in iLogic.  Just a comment on what @WCrihfield posted, the DrawingPrintManager settings do not apply to the PDF translator, only the NameValueMap Options parameter is used.
