- Mute
- Permalink
- Report
Hi @TGibson7A8HD. Since the options for exporting an (.idw) drawing document to PDF do not include anything about scaling or paper size, I assume that it must look at the current 'Print Setup' and/or printing settings for things like page size, orientation, and scaling. That is likely why your other code works better, because it is specifying printer settings, then printing to a PDF printer directly. Another thing that might help would be if your drawing sheet's are designed to be the same size as the paper size you will be printing them to. When that is done, you can pretty much print at 100% or 'Actual' scale and what you have on your drawing sheet on screen will fit the paper perfectly when you print.
I assume that in this case, we just need to incorporate some DrawingPrintManager related code into the loop, just before we export the PDF, so it will know the intended paper size, orientation, and scale better before exporting. I noticed some inconsistencies between the settings of your single PDF export code and your batch PDF export codes, so I was not sure how you really wanted it set-up. In the single export, you have AllColorsAsBlack set to True, but in the PDF options, you have 'All_Color_As_Black' set to 0 (zero), which represents False. Similarly, in the single export code you are not specifying a setting for 'RemoveLineWeights', but within the batch PDF export code, you have the 'Remove_Line_Weights' setting set to 1 (which represents True). I think that is normally False, but no default is documented.
You can give this a try if you want. I just injected some of the DrawingPringManager settings into the loop as mentioned. You may want to adjust those print settings if they do not look correct to your needs.
Sub Main
'PDF all IDW in Directory.iLogicVb:
Dim oPath As String = GetFolder
If oPath = "" Then Exit Sub
If MsgBox("This will write PDF files from all idw files in this location: " & vbCr & vbCr & _
oPath & vbCr & vbCr & " *** Are you sure you want to do this? ***", vbOKCancel + vbExclamation, _
"Batch Write PDF Files") = vbCancel Then Exit Sub
'get PDF target folder path
Dim oFolder As String = oPath & "\" & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
Dim MyFiles As String()
' Sets up the variable "MyFile" to be each file in the directory
' This example looks for all the files that have an .idw extension.
' This can be changed to whatever extension is needed. Also, this
' macro searches the current directory and all sub-directories.
MyFiles = System.IO.Directory.GetFiles(oPath, "*.idw", System.IO.SearchOption.AllDirectories)
'get the PDF Translator AddIn, create variables, and set most options before loop
Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 1
'oOptions.Value("Custom_End_Sheet") = 4
' Starts the Loop, which will Continue Until there are no more files found.
ThisApplication.SilentOperation = True
For Each MyFile As String In MyFiles
' Opens the file and saves as PDF. This can be
' changed to any procedure that would be needed to run on every
' file in the directory such as opening each file.
Dim drawDoc As DrawingDocument = ThisApplication.Documents.Open(MyFile, False)
If drawDoc.DocumentType <> kDrawingDocumentObject Then Continue For
'set print settings
Dim oDPrintMgr As DrawingPrintManager = drawDoc.PrintManager
oDPrintMgr.AllColorsAsBlack = True
oDPrintMgr.NumberOfCopies = 1
oDPrintMgr.Orientation = PrintOrientationEnum.kPortraitOrientation
oDPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeLedger '11 x 17 inches
oDPrintMgr.PrintRange = PrintRangeEnum.kPrintAllSheets
oDPrintMgr.RemoveLineWeights = False
oDPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
Dim oFileName As String = System.IO.Path.GetFileNameWithoutExtension(drawDoc.FullFileName)
oFileName = oFolder & "\" & oFileName & ".pdf"
oDataMedium.FileName = oFileName
Try
oPDFAddIn.SaveCopyAs(drawDoc, oContext, oOptions, oDataMedium)
Catch
Logger.Error("Failed to export following drawing as PDF:" & vbCrLf & drawDoc.FullFileName)
End Try
drawDoc.ReleaseReference
drawDoc = Nothing
Next
ThisApplication.SilentOperation = False
ThisApplication.Documents.CloseAll(True) 'close all unreferenced documents
Shell("explorer.exe " & oFolder, vbNormalFocus)
End Sub
Function GetFolder() As String
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = "C:\$Workspace\Engineering Data"
oFileDlg.CancelError = True
oFileDlg.MultiSelectEnabled = False
oFileDlg.Filter = "All Files (*.*)|*.*"
oFileDlg.DialogTitle = "Choose a Directory with IDW's and/or Sub-Directories with IDW's"
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return Nothing
ElseIf oFileDlg.FileName <> "" Then
oPath = System.IO.Path.GetDirectoryName(oFileDlg.FileName)
Return oPath
End If
End Function
Wesley Crihfield
(Not an Autodesk Employee)
