JelteDeJong
in reply to: K.clement
Looking at the code I expect this is not an iLogic rule. (But an addin?) Anyway, I guess that your function looks something like this:
Public Sub YourFunction(oOcc As ComponentOccurrence)
	Dim oADef As ComponentDefinition = g_inventorApplication.ActiveDocument.ComponentDefinition
	Dim oAsmXYPlane As WorkPlane = oADef.WorkPlanes.Item(3) 'Assembly XY Plane
	Dim oAsmZAxis As WorkAxis = oADef.WorkAxes.Item(3) 'Assembly Z Axis
	Dim oODef As ComponentDefinition = oOcc.Definition
	Dim oOccXYPlane As WorkPlane = oODef.WorkPlanes.Item(3) 'Occurrence XY Plane
	Dim oOccZAxis As WorkAxis = oODef.WorkAxes.Item(3) 'Occurrence Z Axis
	oOcc.CreateGeometryProxy(oOccXYPlane, oOccXYPlane)
	oOcc.CreateGeometryProxy(oOccZAxis, oOccZAxis)
End Sub
What I understand from the Microsoft link that you send is that your function is not defined correctly.
Did you try using the keywords ByVal or ByRef? Something like this:
Public Sub YourFunction(ByVal oOcc As ComponentOccurrence)
or
Public Sub YourFunction(ByRef oOcc As ComponentOccurrence)
Jelte de Jong
Blog: hjalte.nl - github.com
