phankinsTURWH
474 Views, 8 Replies
Changing the balloon style based on assembly or part within an assembly drawing
So I am mildly familiar with various coding langue's and have some experience writing code but I am still very new at this. The goal would be that I open the drawing document and run the rule and all of the .ipt parts within the assembly would be un-changed while all of the .iam files within the assembly would ahve there balloons on the sheets altered to a style I created.
I found 2 methods that work separate and I though I could combine them and it would work fine but it doesnt.
The first one changes all the balloons to a new style as shown below and this works as is.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oStyles As DrawingStylesManager
oStyles = oDrawDoc.StylesManager
'Dim oActiveSheet As Sheet
'oActiveSheet = oDrawDoc.ActiveSheet
Dim oSheet As Sheet
Dim oBalloon As Balloon
Dim oDoc As Document
For Each oSheet In oDrawDoc.Sheets
	For Each oBalloon In oSheet.Balloons
		oBalloon.Style = oStyles.BalloonStyles.Item("SUB")
	Next
Next
The next one makes a text box appear if the overall doc is an assembly or part as shown below.
'start of iLogic rule - - - - - - - - - - - - - - - - - -
doc = ThisDoc.ModelDocument
 'check file type
If doc.DocumentType = kPartDocumentObject Then
MessageBox.Show("This is a part file.", "iLogic")
Else If doc.DocumentType = kAssemblyDocumentObject Then
MessageBox.Show("This is an assembly file.", "iLogic")
End If
 'end of iLogic rule - - - - - - - - - - - - - - - - - -
 When I tried to combine them everything broke and I'm stuck as shown below.
Dim Doc As DrawingDocument
Dim oSheet As Sheet
'Dim Doc As Document
For Each oDoc In oSheet.Documents
	If Doc.DocumentType = kPartDocumentObject Then
	'MessageBox.Show("This is a part file.", "iLogic")
	Else If Doc.DocumentType = kAssemblyDocumentObject Then
	'MessageBox.Show("This Is an assembly File.", "iLogic")
	End If
Next
 Any help would be appreciated if this is the wrong approach for some reason feel free to let me know.
