- Mute
- Permalink
- Report
Batch PDF multiple IDWs with Ilogic Size Issue
I have two Ilogic codes I use. One for exporting the open IDW as a PDF and one for Batch Exporting all in a selected folder to PDFs.
Single Export code actually calls for the sizing of the print
Batch Export code is calling for something other than printing, and I cant figure out where to incorporate print settings.
My workspace in Inventor is 34"x22" for modeling purposes, but our printers for real paper are 11"x17" and when printing a PDF sized 34"x22" to a real printer paper size 11"x17" it has 4" margins and is visually cluttered on the paper.
I am trying to figure out a way to make the Batch Export to include either scaling 50% or forcing the paper size to 11x17 so the resulting PDFs are all 11x17, just like as if I had done the single export.
This is the first string, that functions PERFECTLY, but only does the open IDW.
'Save IDW as PDF
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
MsgBox("This Rule must be Run from a Drawing File", 64,"iLogic Message")
Exit Sub
End If
Dim oDrawDoc As Document
oDrawDoc = ThisApplication.ActiveDocument
Dim oPrintMgr As PrintManager
oPrintMgr = oDrawDoc.PrintManager
'specify your printer name
oPrintMgr.Printer = "CutePDF Writer"
oPrintMgr.PrintRange = kPrintAllSheets
oPrintMgr.AllColorsAsBlack = True
oPrintMgr.Orientation = kPortraitOrientation
oPrintMgr.Scale = kPrintBestFitScale
oPrintMgr.PaperSize = kPaperSizeLedger
oPrintMgr.SubmitPrint
' oDoc = ThisDoc.Document
' Dim oFileDlg As Inventor.FileDialog = Nothing
' InventorVb.Application.CreateFileDialog(oFileDlg)
' oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
' oFileDlg.FileName = iProperties.Value("Project", "Part Number")
' oFileDlg.CancelError = True
' On Error Resume Next
' oFileDlg.ShowSave()
' If Err.Number <> 0 Then
' MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
' ElseIf oFileDlg.FileName <> "" Then
' MyFile = oFileDlg.FileName & ".pdf"
' End If
' ' Get the PDF translator Add-In.
' Dim oPDFTrans As TranslatorAddIn
' oPDFTrans = ThisApplication.ApplicationAddIns.ItemById( _
' "{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
' If oPDFTrans Is Nothing Then
' MsgBox ("Could not access PDF translator.", 64, "iLogic Message")
' Exit Sub
' End If
' ' Create some objects that are used to pass information to the translator Add-In.
' Dim oContext As TranslationContext
' oContext = ThisApplication.TransientObjects.CreateTranslationContext
' Dim oOptions As NameValueMap
' oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Dim oData As DataMedium
' oData = ThisApplication.TransientObjects.CreateDataMedium
' If oPDFTrans.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
' oOptions.Value("Sheet_Range") = kPrintAllSheets
' oContext.Type = kFileBrowseIOMechanism
' oData.FileName = MyFile
' End If
' ' Call the translator.
' oPDFTrans.SaveCopyAs(ThisApplication.ActiveDocument,oContext, oOptions, oData)
And this Below is the Batch editor that prints in true size, this is the one i need to edit to include the resize but i am not sure how.
'PDF all IDW in Directory.iLogicVb: Dim oFileDlg As Inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.InitialDirectory = "C:\$Workspace\Engineering Data" oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = False oFileDlg.Filter = "All Files (*.*)|*.*" oFileDlg.DialogTitle = "Choose a Directory with IDW's and/or Sub-Directories with IDW's" On Error Resume Next oFileDlg.ShowOpen() If Err.Number <> 0 Then Return ElseIf oFileDlg.FileName <> "" Then oPath = System.IO.Path.GetDirectoryName(oFileDlg.FileName) End If If MsgBox("This will write PDF files from all idw files in this location: " & vbCr & vbCr & _ oPath & vbCr & vbCr & " *** Are you sure you want to do this? ***", vbOKCancel + vbExclamation, _ "Batch Write PDF Files") = vbCancel Then Exit Sub 'get PDF target folder path oFolder = oPath & "\" & "PDF" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If Dim MyFiles As String() ' Sets up the variable "MyFile" to be each file in the directory ' This example looks for all the files that have an .idw extension. ' This can be changed to whatever extension is needed. Also, this ' macro searches the current directory and all sub-directories. MyFiles = System.IO.Directory.GetFiles(oPath, "*.idw", System.IO.SearchOption.AllDirectories) ' Starts the Loop, which will Continue Until there are no more files found. For Each MyFile As String In MyFiles ' Opens the file and saves as PDF. This can be ' changed to any procedure that would be needed to run on every ' file in the directory such as opening each file. ThisApplication.SilentOperation = True Dim partDoc As Document = ThisApplication.Documents.Open(MyFile, False) On Error Resume Next If partDoc.DocumentType = kDrawingDocumentObject Then oFileName = IO.Path.GetFileName(partDoc.FullFileName) oFileName = Left(oFileName, Len(oFileName) -4) oFileName = oFolder & "\" & oFileName & ".pdf" oPDFAddIn = partDoc.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 1 'oOptions.Value("Custom_End_Sheet") = 4 End If oDataMedium.FileName = oFileName partDoc.SaveAs(oFileName, True) End If partDoc.Close(False) partDoc = Nothing ThisApplication.SilentOperation = False Next Shell("explorer.exe " & oFolder,vbNormalFocus)
Any Insite would be great, I've searched the forums and find lots of relevant posts but nothing that I can get working.
[Inventor 2020, Updated.
Intel Xeon e5-1620
26gb ram
Quadro K4000]
