- Mute
- Permalink
- Report
Hi @rip2A4H8. There is a place within the Application Options > File tab, to enter (or browse for) the location of your "Default VBA project". If you are creating your VBA macros within that default VBA project file, then that is where they will be. Of course you can also create other application level VBA projects, but those should also likely be in the same location, and you can also create VBA macros within documents. If you created the macro in a document project, it will be saved within the document itself, instead of an external file. However, if you are talking about external iLogic rules, instead of VBA macros, that is specified here: Tools tab > Options panel > iLogic Configuration (you may have to expand the Options panel to see this button). When you click that button, it brings up a dialog. You would need to specify 1 or more directories in the upper portion of that.
Wesley Crihfield
(Not an Autodesk Employee)
