Here is what I had in mind. This is really part specific and can be used to show parts in the drawing which might be hidden in assembly. It is useful for standard assemblies/drawings.
Found this @ https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-to-remove-component-visibilit...
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oActiveSheet As Sheet
oActiveSheet = oDoc.ActiveSheet
Dim oDrawingView As DrawingView
oDrawingView = oActiveSheet.DrawingViews(1)
Dim oRefDoc As AssemblyDocument
oRefDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oAssDef As AssemblyComponentDefinition
oAssDef = oRefDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
For Each oOcc In oAssDef.Occurrences
       If oOcc.Name = "Arrow up:1" Then
          Call oDrawingView.SetVisibility(oOcc, True)
       End If
	   If oOcc.Name = "Arrow down:1" Then
       End If
    Next
Tom
