- Mute
- Permalink
- Report
Here is a simple version of how to copy a sketch using the method CopyContentsTo. Pay attention to the objects that change between the source and target. These are Document, ComponentDefinition and Sketch. These object names have been renamed to make it easier to track what is happening.
Option1:
'a reference to the Source document. Dim oSourceDoc As PartDocument oSourceDoc = ThisApplication.Documents.ItemByName("C:\Users\1234-M-001.ipt") 'a reference to the component definition. Dim oSourceDef As PartComponentDefinition oSourceDef = oSourceDoc.ComponentDefinition 'a reference to the first sketch in the part. Dim oSketchToCopy As PlanarSketch oSketchToCopy = oSourceDef.Sketches.Item(1) 'a reference to the the Target document you launch the rule from. Dim oTargetDoc As PartDocument oTargetDoc = ThisDoc.Document 'a reference to the component definition. Dim oTargetDef As PartComponentDefinition oTargetDef = oTargetDoc.ComponentDefinition 'Create a new sketch on the XY plane. Dim oNewSketch As PlanarSketch oNewSketch = oTargetDef.Sketches.Add(oTargetDef.WorkPlanes.Item(3)) 'Copy the sketch from source to target. oSketchToCopy.CopyContentsTo(oNewSketch)
There is an optional piece of code to move the sketch once pasted. It gathers each piece of the sketch into a collection and moves it to a new location.
' 'Optional move sketch to new location ' Dim oSketchEnts As ObjectCollection ' oSketchEnts = ThisApplication.TransientObjects.CreateObjectCollection ' Dim oSketchEnt As SketchEntity ' For Each oSketchEnt In oNewSketch.SketchEntities ' Call oSketchEnts.Add(oSketchEnt) ' Next ' ' Translate all sketch entities in the new sketch. ' oNewSketch.MoveSketchObjects(oSketchEnts, ThisApplication.TransientGeometry.CreateVector2d(10, 0))
Option2:
Using the API sample was more difficult than expected. The reason being it just mimicks the manual operation by using the command manager which is the same as hitting a button on the user interface. To achieve a result it is necessary to activate the source document to correctly pick up the sketch. Here is the modifications required to copy from one source to another.
Disable the screen update when documents are being activated ThisApplication.ScreenUpdating = False 'a reference to the Source document. Dim oSourceDoc As PartDocument oSourceDoc = ThisApplication.Documents.ItemByName("C:\Users\1234-M-001.ipt") oSourceDoc.Activate 'a reference to the component definition. Dim oSourceDef As PartComponentDefinition oSourceDef = oSourceDoc.ComponentDefinition 'a reference to the first sketch in the part. Dim oSketchToCopy As PlanarSketch oSketchToCopy = oSourceDef.Sketches.Item(1) 'Select the sketch to copy. oSourceDoc.SelectSet.Clear oSourceDoc.SelectSet.Select(oSketchToCopy) 'Execute the copy command. Dim oCopyControlDef As ControlDefinition oCopyControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd") oCopyControlDef.Execute 'a reference to the active document. 'This assumes a part document is active. Dim oDoc As PartDocument oDoc = ThisDoc.Document oDoc.Activate 'a reference to the component definition. Dim oDef As PartComponentDefinition oDef = oDoc.ComponentDefinition 'Create a new sketch on the XY plane. Dim oNewSketch As PlanarSketch oNewSketch = oDef.Sketches.Add(oDef.WorkPlanes.Item(3)) 'Put the sketch in edit mode. oNewSketch.Edit 'Execute the paste command. Dim oPasteControlDef As ControlDefinition oPasteControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd") oPasteControlDef.Execute ThisApplication.ScreenUpdating = True
Or if this helped you, please, click (like)
Regards
Alan
