phani.gampala
in reply to: A.Acheson
Thank you very much for the reply @A.Acheson
I have tried leaving the name blank like you mentioned. Then inventor just creates parts with the numbering scheme set automatically. However, I dont want to manually add the constraint name for every single fastener placed. For example there might already be a 100 M10 Flat Washers in the assembly added before. If I run the code it will place M10 Flat Washer:101 like you said but wont update the mate number to mate:101. It will just replace some older constraint. I need a way to update the constraint name automatically to suit the new instance name.
