07-26-2022
11:33 PM
- Mute
- Permalink
- Report
07-26-2022
11:33 PM
Hello everyone,
I'm trying to place fasteners as sets, example: M10 x 25 SET SCREW, M10 FLAT WASHER AND M10 SPRING WASHER into my assembly so that I can constrain them to my assembly quicker. However when I place these components from content center and constrain them using ilogic it only works the first time. When a second instance of the fastener is placed (for example: SS Flat Washers 10 mm:2), how do I update the mate constraint that is supposed to constrain the fastener set. I have only pasted the problematic portion of the code. I need the code to place new instances every single time it is run and constrain them in the same way.
Component1 = Components.AddContentCenterPart("SS Flat Washers 10 mm:1","Fasteners:Washers:Plain","SS Flat Washers", {"STOCK_TYPE","S","NND","10"}, position := Nothing, grounded := False, visible := True, appearance := Nothing) Component2 = Components.AddContentCenterPart("SS Spring Washers 10 mm:1","Fasteners:Washers:Spring","SS Spring Washers", {"STOCK_TYPE","S","NND","10"}, position := Nothing, grounded := False, visible := True, appearance := Nothing) Constraints.AddMate("", "SS Flat Washers 10 mm:1", "Work Axis1", "SS Spring Washers 10 mm:1", "Work Axis1", offset := 0.0, e1InferredType := InferredTypeEnum.kNoInference, e2InferredType := InferredTypeEnum.kNoInference, solutionType := MateConstraintSolutionTypeEnum.kNoSolutionType, biasPoint1 := Nothing, biasPoint2 := Nothing) Constraints.AddMate("", "SS Flat Washers 10 mm:1", "YZ PLANE", "SS Spring Washers 10 mm:1", "YZ PLANE", offset := 0.0, e1InferredType := InferredTypeEnum.kNoInference, e2InferredType := InferredTypeEnum.kNoInference, solutionType := MateConstraintSolutionTypeEnum.kNoSolutionType, biasPoint1 := Nothing, biasPoint2 := Nothing)
