theo.bot
in reply to: fdo.llanos99
@fdo.llanos99 ,
Check if your column in your table is linked to your template parameter.
To avoid the warning about the file naming, you need to add all custom column to your filename column. In this sample I added the custom length to the expression.
But if you are using a Autofile naming function like Autodesk Vault professional is offering, you can ignore this warning. It's just to make sure you create unique filenames.
