07-19-2022
01:25 AM
- Mute
- Permalink
- Report
07-19-2022
01:25 AM
Hello Everyone,
I have searched the forum for this solution but i can't seem to find the exact solution.
I have a Ilogic to auto place a predefined style partlist on my drawing. It also reorders the partlist according to my preferences.
The problem is that i can't get the position correct. I want it to be on the position of the blue point.
I've tried the offset possibility. But my problem was that if i place a different assembly with a different partlist the offset position changes. So no fixed value.
Can somebody please help me correct my Ilogic Code?
Kind regards,
Koen Roovers
iLogicVb.UpdateWhenDone = True ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet ' Set a reference to the first drawing view on ' the sheet. This assumes the first drawing ' view on the sheet is not a draft view. Dim oDrawingView As DrawingView Try oDrawingView = oSheet.DrawingViews(1) Catch MessageBox.Show("No View found. Can not continue", "iLogic") Return End Try ' Set a reference to th sheet's border Dim oBorder As Border oBorder = oSheet.Border Dim oPlacePoint As Point2d If Not oBorder Is Nothing Then ' A border exists. The placement point oX = oBorder.RangeBox.MaxPoint.X oY = oBorder.RangeBox.MaxPoint.Y oPlacePoint = ThisApplication.TransientGeometry.CreatePoint2d(oX, oY) Else ' There is no border oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(20, 20) iLogicVb.UpdateWhenDone = True End If Dim oPartslist As PartsList Try 'look for the first parts list found on the sheet 'if succesful finding it, 'tell the user,then Do Nothing oPartslist = oSheet.PartsLists(1) MessageBox.Show("There is an existing Parts List", "iLogic") Catch ' Create the parts list. oPartslist = oSheet.PartsLists.Add(oDrawingView, oPlacePoint) 'set parts list to a specific style oPartslist.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Purchase List (Kieu)") Dim oPartsList1 As PartsList oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1) oPartsList1.Sort("Opmerkingen", 1, "Kodenummer", 1) oPartsList1.Renumber End Try
