07-13-2022
05:10 PM
- Mute
- Permalink
- Report
07-13-2022
05:10 PM
Can you explain where you need the filename changed? Is the iPart factory in a library or in your workspace folder? The iPart member name or partnumber can be set in the iPart factory table. No ilogic should be needed. If you can supply some more information with images etc the answer can correctly target your request.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
