WCrihfield
in reply to: djbounds
Since that folder is usually a couple sub-folders below the 'Design Data' folder, you may have to make sure it is in the same folder structure under your new 'Design Data' folder on your new PC, then make sure you go into Application Options > File tab...and specify the full path to that 'Design Data' folder there.  Then also within your Project File's settings, under Folder Options, there is also a place to specify where the 'Design Data' folder is.  Make sure both are set to the same location.  I have most of my stuff pointing to a shared network drive location, so everyone on the 'team' is pointing to all the same resources all the time.
Wesley Crihfield
(Not an Autodesk Employee)
