pavol_krasnansky
241 Views, 0 Replies
Get Part Icon iProperties
Hi, I have program for loading thumbnails from BOM in the visual studio (in the attachment). It works correctly. I have the same program for icons but it doesn't work. Can someone help me? Thank you.
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports System.Math
Imports System.IO
Imports Inventor
Public Class Form1
    Public Shared oInventor_App As Inventor.Application
    Private Sub Button_Load_BOM_Click(sender As Object, e As EventArgs) Handles Button_Load_BOM.Click
        Try
            'oInventor_App = GetObject(, "Inventor.Application")
            oInventor_App = Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MessageBox.Show("Musí byť spustený Autodesk Inventor!", "Chyba", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
        Dim oStlpec_Ikona As New DataGridViewImageColumn()
        DataGridView_BOM.Columns.Add(oStlpec_Ikona)
        oStlpec_Ikona.HeaderText = ""
        oStlpec_Ikona.Name = "0"
        oStlpec_Ikona.ImageLayout = DataGridViewImageCellLayout.NotSet
        DataGridView_BOM.Columns("0").ReadOnly = True
        DataGridView_BOM.Columns("0").Visible = True
        DataGridView_BOM.Columns.Add("1", "Item")
        DataGridView_BOM.Columns("1").ReadOnly = True
        DataGridView_BOM.Columns("1").Visible = True
        Dim oStlpec_Nahlad_Modelu As New DataGridViewImageColumn()
        DataGridView_BOM.Columns.Add(oStlpec_Nahlad_Modelu)
        oStlpec_Nahlad_Modelu.HeaderText = "Thumbnail"
        oStlpec_Nahlad_Modelu.Name = "2"
        oStlpec_Nahlad_Modelu.ImageLayout = DataGridViewImageCellLayout.NotSet
        DataGridView_BOM.Columns("2").ReadOnly = True
        DataGridView_BOM.Columns("2").Visible = True
        If oInventor_App.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim oAsmDoc As AssemblyDocument
            oAsmDoc = oInventor_App.ActiveDocument
            Dim apprentice As New ApprenticeServerComponent
            Dim doc As ApprenticeServerDocument
            doc = apprentice.Open(oAsmDoc.FullFileName)
            Dim oBOM As BOM
            oBOM = doc.ComponentDefinition.BOM
            'Dim oBOM As BOM
            'oBOM = oAsmDoc.ComponentDefinition.BOM
            Dim oBOMView As BOMView
            oBOMView = oBOM.BOMViews.Item(1)
            Dim oBOMRow As BOMRow
            Dim oCompDef As ComponentDefinition
            For i = 1 To oBOMView.BOMRows.Count
                oBOMRow = oBOMView.BOMRows.Item(i)
                oCompDef = oBOMRow.ComponentDefinitions.Item(1)
                Dim oIcon As stdole.IPictureDisp
                oIcon = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Icon").Value
                Dim oImageIcon As System.Drawing.Image
                oImageIcon = IPictureDispConverter.PictureDispToImage(oIcon)
                Dim oBitmapIcon As New Bitmap(20, 20)
                Dim oImageIcon_Resize As System.Drawing.Graphics
                oImageIcon_Resize = Graphics.FromImage(oBitmapIcon)
                Try
                    oImageIcon_Resize.DrawImage(oImageIcon, 0, 0, 100, 100)
                    'MsgBox(ex.ToString)
                End Try
                oIcon = Nothing
                oImageIcon = Nothing
                oImageIcon_Resize = Nothing
                Dim oThumbnail As stdole.IPictureDisp
                oThumbnail = Nothing
                For j = 1 To 1000
                    oThumbnail = oCompDef.Document.PropertySets.Item("Inventor Summary Information").Item("Thumbnail").Value
                    If oThumbnail.Handle > 0 Then
                        Exit For
                    End If
                Next
                Dim oImage As System.Drawing.Image
                oImage = IPictureDispConverter.PictureDispToImage(oThumbnail)
                Dim oBitmap As New Bitmap(100, 100)
                Dim oImage_Resize As System.Drawing.Graphics
                oImage_Resize = Graphics.FromImage(oBitmap)
                Try
                    oImage_Resize.DrawImage(oImage, 0, 0, 100, 100)
                End Try
                oImage = Nothing
                oImage_Resize = Nothing
                DataGridView_BOM.Rows.Add(oBitmapIcon, i, oBitmap)
            Next
            doc.Close()
        End If
        oInventor_App = Nothing
        Button_Load_BOM.Enabled = False
    End Sub
End Class
Public NotInheritable Class IPictureDispConverter : Inherits System.Windows.Forms.AxHost
    Private Sub New()
        MyBase.New("{63109182-966B-4e3c-A8B2-8BC4A88D221C}")
    End Sub
    Public Shared Function PictureDispToImage(pictureDisp As Inventor.IPictureDisp) As Image
        Try
            Return GetPictureFromIPicture(pictureDisp)
            Return Nothing
        End Try
    End Function
End Class
