06-29-2022
11:59 AM
- Mute
- Permalink
- Report
06-29-2022
11:59 AM
I can get the code to create both the .stp and .pdf; however, the .pdf is not created in the selected directory, it defaults to the same directory as the .idw file.
Any help would be greatly appreciated.
Dim doc As DrawingDocument = ThisDoc.Document Dim sheet As Sheet = doc.ActiveSheet Dim view As DrawingView = sheet.DrawingViews.Item(1) Dim partDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument ' Get current location of this file Dim ExportPath As String = ThisDoc.Path ' Check that this file has been saved and actually exists on disk If String.IsNullOrEmpty(ExportPath) Then MsgBox("This file has not yet been saved and doesn't exist on disk!" _ & vbLf & "Please save it first", 64, "Lord iLogic") Return End If Dim drawingNumber = iProperties.Value("Custom", "Drawing Number") Dim dialog As Inventor.FileDialog ThisApplication.CreateFileDialog(dialog) dialog.InitialDirectory = ExportPath dialog.FileName = drawingNumber dialog.DialogTitle = "Save" dialog.Filter = "Step files(*.stp)|*.stp|All Files (*.*)|*.*" dialog.CancelError = True Try dialog.ShowSave() Catch ex As Exception Return End Try ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = dialog.FileName oSTEPTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData) End If oFileName = iProperties.Value("Custom", "Drawing Number") ' Define the filename of the file to be exported ' In this Case it Is a PDF file extension ExportFilename = oFileName & ".pdf" oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'set PDF Options oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'Set the PDF target file name oDataMedium.FileName = ExportPath & ExportFilename Try 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Catch MessageBox.Show("Error writing out PDF", "iLogic") bError = True End Try If bError <> True Then 'Ask user If they want To open (launch) the file we just exported... oMessage = "File exported: " & _ ExportPath & ExportFilename & vbLf & vbLf & _ "Do you want to open the PDF Now?" oQuestion = MessageBox.Show(oMessage, _ "Lord iLogic - File Exported",MessageBoxButtons.YesNo) If oQuestion = vbYes Then ThisDoc.Launch(ExportPath & ExportFilename) End If End If
