donnie.morris
1201 Views, 10 Replies
Export PDF and STP in one rule
I have a piece of code that exports a file from the .idw to a STP. I was wondering if that code could be adapted to export both a .stp and .pdf? Is this possible?
Here's the code: Export to STP
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim partDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
' Get current location of this file
Dim ExportPath As String = ThisDoc.Path
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ExportPath) Then
        MsgBox("This file has not yet been saved and doesn't exist on disk!" _
        & vbLf & "Please save it first", 64, "Lord iLogic")
        Return
End If
Dim drawingNumber = iProperties.Value("Custom", "Drawing Number")
Dim dialog As Inventor.FileDialog
ThisApplication.CreateFileDialog(dialog)
dialog.InitialDirectory = ExportPath
dialog.FileName = drawingNumber
dialog.DialogTitle = "Save"
dialog.Filter = "Step files(*.stp)|*.stp|All Files (*.*)|*.*"
dialog.CancelError = True
Try
        dialog.ShowSave()
Catch ex As Exception
        Return
End Try
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = dialog.FileName
        oSTEPTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData)
End If
