donnie.morris
1211 Views, 10 Replies
Export PDF and STP in one rule
I have a piece of code that exports a file from the .idw to a STP. I was wondering if that code could be adapted to export both a .stp and .pdf? Is this possible?
Here's the code: Export to STP
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim partDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
' Get current location of this file
Dim ExportPath As String = ThisDoc.Path
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ExportPath) Then
        MsgBox("This file has not yet been saved and doesn't exist on disk!" _
        & vbLf & "Please save it first", 64, "Lord iLogic")
        Return
End If
Dim drawingNumber = iProperties.Value("Custom", "Drawing Number")
Dim dialog As Inventor.FileDialog
ThisApplication.CreateFileDialog(dialog)
dialog.InitialDirectory = ExportPath
dialog.FileName = drawingNumber
dialog.DialogTitle = "Save"
dialog.Filter = "Step files(*.stp)|*.stp|All Files (*.*)|*.*"
dialog.CancelError = True
Try
        dialog.ShowSave()
Catch ex As Exception
        Return
End Try
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = dialog.FileName
        oSTEPTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData)
End If
Sure, after you export to .stp, export to pdf. There's an example in the API docs: Export to PDF
Some of the things in that code you've already done to get the .stp so you won't need to duplicate them for the pdf.
I can get the code to create both the .stp and .pdf; however, the .pdf is not created in the selected directory, it defaults to the same directory as the .idw file.
Any help would be greatly appreciated.
	Return
End If
Try
	dialog.ShowSave()
	Return
End Try
	' Other options...
End If
oFileName = iProperties.Value("Custom", "Drawing Number")
' Define the filename of the file to be exported
' In this Case it Is a PDF file extension
ExportFilename = oFileName & ".pdf"
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'set PDF Options
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'Set the PDF target file name
oDataMedium.FileName = ExportPath & ExportFilename
Try
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
	MessageBox.Show("Error writing out PDF", "iLogic")
	bError = True
End Try
If bError <> True Then
	'Ask user If they want To open (launch) the file we just exported...
	oMessage = "File exported: " & _
			ExportPath & ExportFilename & vbLf & vbLf & _
			"Do you want to open the PDF Now?"
	oQuestion = MessageBox.Show(oMessage, _
	"Lord iLogic - File Exported",MessageBoxButtons.YesNo)
	If oQuestion = vbYes Then
		ThisDoc.Launch(ExportPath & ExportFilename)
	End If
End If
If you want both the .stp and the .pdf file in the same directory and with the same filename (except for extension), you can still use the result from the first FileDialog you use. You just have to change the extension of the save file, which is fairly easy to do. In your PDF section, instead of
use this:
oDataMedium.FileName = System.IO.Path.GetFileNameWithoutExtension(dialog.FileName)&".pdf"
So this rule looks at .idw files that contain an .ipt in order to create the .stp file. Can the rule be written for an .idw  that only contains .iam files.
I’m looking for a rule that will create .stp files for all .ipt files contained in the .iam used.
I’m not sure I’m asking the question correctly.
The rule can be written for an .idw with an assembly, or it can be written for an assembly itself. Which do you need?
I would like the rule to work from the .idw file.
This rule assumes view #1 (normally the first view you placed) has the assembly you want to export .stp files from. It also assumes there are only parts, no subassemblies.
Imports System.Windows.Forms
Dim assembyDoc As AssemblyDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
	MsgBox("This file has not yet been saved and doesn't exist on disk!")
	Return
End If
Dim dialog = New FolderBrowserDialog()
dialog.SelectedPath = ExportPath
If dialog.ShowDialog() = DialogResult.OK Then
	For Each occurrence As ComponentOccurrence In assembyDoc.ComponentDefinition.Occurrences
		If (occurrence.DefinitionDocumentType = kPartDocumentObject) Then
			Dim partDoc As PartDocument = occurrence.Definition.Document
			Dim stepTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
			Dim translatorContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
			Dim translatorOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
			If stepTranslator.HasSaveCopyAsOptions(partDoc, translatorContext, translatorOptions) Then
				translatorOptions.Value("ApplicationProtocolType") = 3
				translatorContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
				Dim translatorData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
				translatorData.FileName = dialog.SelectedPath & "\" & System.IO.Path.ChangeExtension(partDoc.DisplayName, ".stp")
				stepTranslator.SaveCopyAs(partDoc, translatorContext, translatorOptions, translatorData)
			End If
		End If
	Next
End If
Is there a way to make the view selectable instead of defaulting to View 1?
Just change the first part to allow a view selection:
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
Hi, here code to export to STEP
sub main()
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'Set the destination file name
oDataMedium.FileName = path_and_name & ".stp"
'Publish document.
ThisDoc.Document.SaveAs(oDataMedium.FileName , True)
end sub
