- Mute
- Permalink
- Report
Replace Imported Component
I have an existing Inventor Assembly references a STEP file as a Reference Model. I would like to rename the step file to something else and replace the reference via the API.
If this was an Inventor document reference it would be straightforward - I can use the Replace method on the ComponentOccurrence(s) that reference the document and be done. However, if it is a referenced STEP file, it appears that ComponentOccurrence.Replace, when provided the name of a STEP file, will convert the STEP file - it doesn't continue to reference the STEP file.
I know I can add a new STEP file reference using the AssemblyDocument.ComponentDefinition.ImportedComponents.Add method, but I don't want to add a new one - I want to replace an existing one. Am I missing something or is what I need to do not possible?
- Mute
- Permalink
- Report
Here is a route that might be viable. I haven't tested it to see.
1.Syntax ImportedComponent.ReferencedDocumentDescriptor() As DocumentDescriptor
2.Syntax
DocumentDescriptor.ReferencedFileDescriptor() As FileDescriptor
3.Syntax
FileDescriptor.ReplaceReference( FullFileName As String )
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
It appears that the replace reference mentioned above is not functioning and there is no documented sample to do this, so here is another approach. The manual replace all correctly keeps the reference to an imported component and the import type referenced model. So the below codes simply automates this procedure. Here is the article that references running commands.
' Get the command manager. Dim oCommandMgr As CommandManager = ThisApplication.CommandManager 'Pick occurrence Dim oAssyoOcc As ComponentOccurrence = oCommandMgr.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Occurence") 'Select the chosen occurrence for processing oCommandMgr.DoSelect(oAssyoOcc) 'Clear the clipboard oCommandMgr.ClearPrivateEvents ' Post the filename. Call oCommandMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,"C:\Users\Assembly5.stp") ' Get control definition for the place component command. Dim oControlDef As ControlDefinition= oCommandMgr.ControlDefinitions.Item("AssemblyReplaceAllCmd") ' Execute the command synchronously. Call oControlDef.Execute2(True)
Regards
Alan
