jmacapagal2CD9H
382 Views, 3 Replies
Export to 3D PDF Sample C# Code from the Documentation is not working.
Good day!
I've been working on Exporting to 3d pdf using AnarkCore, however, using the provided sample C# codes from the documentation is not working when I try to use it from a custom addin that I created. Below is the actual error. Do you have any Ideas?
Thank you.
