- Mute
- Permalink
- Report
Export BOM with Template
Since Inventor R2022.1 you can use a template when you export a BOM view when using the interface. (Inventor 2023 Help | Assembly Enhancements | Autodesk)
It looks like these BOM export options are not included in the API (Inventor 2023 Help | BOMView.Export Method | Autodesk).
I tried to use the same way as mentioned in the Partlist export options (Inventor 2023 Help | PartsList.Export Method | Autodesk) But that did not work.
I know there are a lot of work arounds, but it would make life a lot easier if we can export BOM views directly into a excel template using the API.
Does anyone know if these options are supported?
- Mute
- Permalink
- Report
I tried a couple of things. but could not get it to work with an object collection. But if you throw in a string you can set 1 option the table name. it works like this.
Dim doc As AssemblyDocument = ThisDoc.Document Dim bom As BOM = doc.ComponentDefinition.BOM Dim bomView As BOMView = bom.BOMViews.Item("structured") Dim file = "D:\folder\file.xlsx" bomView.Export(file, FileFormatEnum.kMicrosoftExcelFormat, "This_will_become_the_sheet_name")
I guess that this is not what you are looking for. But this makes me expect that it's not possible to set more options.
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
Hi @JelteDeJong,
Thanks for checking. I had the same conclusion when I was trying to make it work.
So for now I simply create a drawing in the background, place and export the partslist then close the drawing without save. It works fine, but I hoped to skip this part of my code and do this directly.
I dropped it in the idea station, so let's vote
API Support for Export BOM with Template - Autodesk Community
