- Mute
- Permalink
- Report
I wrote some code that can go through all my referenced documents, change the job number of the item, save it, and then delete the old file.
However this causes all the links in my assemblies to break. I know there is a FileDecriptor.ReplaceRefrence command, but I do not know how to make sure that the FileDesctriptor is the same document as the on in AllReferencedDocuments.
Because I am using a for each loop, I don't know how to address the FileDescripters enum.
Here Is the code I have so far
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("please only use on an assembly") Exit Sub End If Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim sOldProjectNumber As String = InputBox("Enter old project number", "Old Number",) Dim sNewProjectNumber As String = InputBox("Enter new project number", "New Number") Dim oRefDoc As Document For Each oRefDoc In oDoc.AllReferencedDocuments Dim sOldName As String = System.IO.Path.GetFileName(oRefDoc.FullFileName) If sOldName.Contains(sOldProjectNumber) Then Dim sPath As String = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) Dim sNewName As String = sOldName.Replace(sOldProjectNumber, sNewProjectNumber) Try Dim oRefPropSet As PropertySet = oRefDoc.PropertySets.Item("Design Tracking Properties") Dim oRefProp As [Property] = oRefPropSet.Item("Part Number") oRefProp.Value = sNewName Catch MsgBox(System.IO.Path.GetFileName(oRefDoc.FullFileName)) End Try oRefDoc.SaveAs(sPath & "\" & sNewName, True) Dim oDocDesc As FileDescriptor = oDoc.ReferencedDocumentDescriptors.Item(oRefDoc) oDocDesc. System.IO.File.Delete(sPath & "\" & sOldName) End If Next
- Mute
- Permalink
- Report
you could use the AllReferencedOccurrences. Some thing like this:
Dim doc As AssemblyDocument = ThisDoc.Document Dim def As AssemblyComponentDefinition = doc.ComponentDefinition For Each refDoc As Document In doc.AllReferencedDocuments Dim newDoc As Document = CreateNewDoc(refDoc) Dim occs = def.Occurrences.AllReferencedOccurrences(refDoc) For Each occ As ComponentOccurrence In occs occ.ReferencedFileDescriptor.ReferencedDocument(....) Next Next
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
Hey @JelteDeJong Thanks for responding.
I have a couple of questions regarding how your implementation works.
where are you accessing this CreateNewDoc command from, or is this supposed to be a reference to my code doing this?
Can you use a document to select an occurrence? The argument says it should be looking for a component occurrence.
I don't know what .... means. Is this an operator or is this where I am supposed to put my new document
- Mute
- Permalink
- Report
I think you might get by with just using SaveAs to create the copies and swap out the references, see your other thread for an example:
I hope this helps.
Curtis
