Hi @Cadderman ,
For the case with more View reps than positional reps, where multiple products use the same positional reps, you could use something like this ( assuming the parameter list and form are already set up).
I hope this helps.
Curtis
Select Case ProductConfig
	Case "Product Type 1"
		oViewRep = "Product Type 1"
		oPosRep = "PosView1"
	Case "Product Type 2"
		oViewRep = "Product Type 2"
		oPosRep = "PosView2"
	Case "Product Type 3"
		oViewRep = "Product Type 3"
End Select
Dim oDoc As Document
Dim oDef As ComponentDefinition
oDoc = ThisApplication.ActiveDocument
oDef = oDoc.ComponentDefinition
oDef.RepresentationsManager.DesignViewRepresentations.Item(oViewRep).Activate
oDef.RepresentationsManager.PositionalRepresentations.Item(oPosRep).Activate
ThisApplication.ActiveView.Fit
