Cadderman
692 Views, 4 Replies
iLogic and Form Combination To Control View Representations and Positions
I have a model that needs 10 positions and 35 view representations.  This is due to us having 10 Types of item and they can be configured in different positions.  Ideally I would like to be able to toggle the position and view representations by means of a form.
I am wondering if this can be achieved by means of a multiple-value text parameter.  For example if the text parameter was "Product Type 1" the code would give it "View 1" and "Position 1".  If the code was easy enough to work with I can copy and paste the lines in the same iLogic code for each position - ie "Product Type 2" = "View 2" + "Position 1".
Alternatively, if it makes things simpler, I could create a view representation and a positional representation with matching names that would be equal to the text parameter.  If the code can handle that and apply the view and position to match the multi-value text parameter chosen, I can work with that also.
Is this achievable?  The whole purpose is to streamline the model so users can check clashes in different positions with different items in the machine.
Thanks in advance
Hi @Cadderman
Something like this should work. The first example sets the list and uses an input box (rather than a form) ... but if you had the form and list already set up you could use something like the 2nd example.
I hope this helps.
Curtis
1st example
oTrigger = ProductConfig
MultiValue.SetList("ProductConfig", "Product Type 1", "Product Type 2")
oInput = InputListBox("Prompt", MultiValue.List("ProductConfig"), _
"", "iLogic", "List")
If oInput = "" Then Return 'exit rule
Dim oDoc As Document
Dim oDef As ComponentDefinition
oDoc = ThisApplication.ActiveDocument
oDef = oDoc.ComponentDefinition
oDef.RepresentationsManager.DesignViewRepresentations.Item(oInput).Activate
oDef.RepresentationsManager.PositionalRepresentations.Item(oInput).Activate
ThisApplication.ActiveView.Fit
2nd example
oDef.RepresentationsManager.DesignViewRepresentations.Item(ProductConfig).Activate
oDef.RepresentationsManager.PositionalRepresentations.Item(ProductConfig).Activate
Hi @Cadderman ,
For the case with more View reps than positional reps, where multiple products use the same positional reps, you could use something like this ( assuming the parameter list and form are already set up).
I hope this helps.
Curtis
Select Case ProductConfig
	Case "Product Type 1"
		oViewRep = "Product Type 1"
		oPosRep = "PosView1"
	Case "Product Type 2"
		oViewRep = "Product Type 2"
		oPosRep = "PosView2"
	Case "Product Type 3"
		oViewRep = "Product Type 3"
End Select
oDef.RepresentationsManager.DesignViewRepresentations.Item(oViewRep).Activate
oDef.RepresentationsManager.PositionalRepresentations.Item(oPosRep).Activate
Hi @Curtis_Waguespack
Thanks for the codes! I'm just trying to use them in a test model to try out the iLogic.  It works great, thank you so much!
SteveK88
in reply to: Cadderman
FYI, less text using RepresentationsManager......
Select Case Position
	Case "Sitting"
		oViewRep = "View1"
		oPosRep = "Sitting"
	Case "Reaching"
		oViewRep = "View1"
		oPosRep = "Reaching"
	Case "Working"
		oViewRep = "View1"
		oPosRep = "Working"
End Select
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Item(oViewRep).Activate
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.PositionalRepresentations.Item(oPosRep).Activate
