A.Acheson
in reply to: karram
You can first check if the file exist then just delete the file before exporting the New BOM. This will eliminate the need to overwrite the file and prevent the dialog.  Although in my testing the standard BOM export will automatically overwrite the file without the warning dialog. I suspect that the larger rule you are using has other issues with the workflow. Please share the entire rule if this is still an issue.
'Check if file exists, if it does then delete
If System.IO.File.Exists(myXLS_File) Then
	System.IO.File.Delete(myXLS_File)
End If
Regards
Alan
