tmathieson
526 Views, 7 Replies
ilogic code to copy and replace in ana ssembly
Hello All,
i am working on a piece of code that will insert components into an assembly and mate to each other accordingly.  i have this working fine, but i want to take all the component and save them with new names and replace the ones in the assembly, basically  the "Productivity> Save and Replace" command. searching thru the forms her, it seems like the
 (component name).SaveAs (new filename, false)
should save the component with the new name in the same directory as the assembly file, and replace the original part with the newly saved one....
so that is what i am trying to code here, but i keep getting errors like "parameter is incorrect".... on the SaveAs line
	If i = 1 Then
			GROUND = True
			Dim componentB = Components.Add(PLATE_PRE & i, "SC-H-2R-P1.ipt", position := Nothing, grounded := GROUND, visible := True, appearance := asgreen)
			Dim doc As Document = Component.InventorComponent(PLATE_PRE & i).Definition.Document
			File_new_name = "help-" & i
			Logger.Debug(File_new_name)
			doc.SaveAs(File_new_name , False)
			GROUND=False
			GoTo JUMP_NEXT
 its probably something to do with how i am defining the doc variable, but not sure.... any help, as always, would be greatly appreciated.
