- Mute
- Permalink
- Report
How can I tell if an arc curves inwards or outwards?
How can I tell if an arc curves "into" a part or "out of" a part using the edge?
For example, how could I identify the curve on the left (curving in) as -1 and the curve on the right (curving out) as +1?
I extracted the ArcData but can't seem to find a way I can use this to tell which way the arc curves.
Arc3d curve = edge.Geometry;
curve.GetArcData(....);
- Mute
- Permalink
- Report
It depends on reason. here is few aproaches
- Check tangential faces of cylinder face: arcEdge.Faces.TangentiallyConnectedFaces.Count > 0
- Check center point of arc is inside of surface body: SurfaceBody.IsPointInside
- Check the tangent of arc on one of the endpoint and line direction: CurveEvaluator.GetTangent
and so on...
- Mute
- Permalink
- Report
1. I tried this on a part with multiple curves that are in and out and I got the count to be 1 on both the ins and outs.
2. Originally this was the method I was using but then I came across a part that it did not work on. The pic attached is an example. Both the in and out curve have a center point that is not on the face.
3. This works for the part I posted but say if both sides curved outward, the tangent point on the starting point of one curve would point in the opposite direction of the tangent of the starting point on the other curve.
1.
2.
3.
- Mute
- Permalink
- Report
Hi @johnPGNFG
Here is an iLogic example, based on the "Is cylindrical face interior or exterior?" API Help files Sample
I hope this helps.
Curtis
Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument Dim oHLSet As HighlightSet oHLSet = oDoc.CreateHighlightSet Dim oRed As Color oRed = ThisApplication.TransientObjects.CreateColor(255, 0, 0) oRed.Opacity = 0.1 oHLSet.Color = oRed Dim oHLSet2 As HighlightSet oHLSet2 = oDoc.CreateHighlightSet Dim oGreen As Color oGreen = ThisApplication.TransientObjects.CreateColor(0, 255, 0) oHLSet2.Color = oGreen For Each oSolid In oDoc.ComponentDefinition.SurfaceBodies Dim oFace As Face For Each oFace In oSolid.Faces If Not oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then Continue For If oFace.Edges.Count = 2 Then Continue For 'skip holes or full circle cuts Dim oCylinder As Cylinder oCylinder = oFace.Geometry Dim params(1) As Double params(0) = 0.5 params(1) = 0.5 ' Get point on surface at param .5,.5 Dim points(2) As Double Call oFace.Evaluator.GetPointAtParam(params, points) ' Create point object Dim oPoint As Point oPoint = ThisApplication.TransientGeometry.CreatePoint _ (points(0), points(1), points(2)) ' Get normal at this point Dim normals(2) As Double Call oFace.Evaluator.GetNormal(params, normals) ' Create normal vector object Dim oNormal As Vector oNormal = ThisApplication.TransientGeometry.CreateVector _ (normals(0), normals(1), normals(2)) ' Scale vector by radius of the cylinder oNormal.ScaleBy(oCylinder.Radius) ' Find the sampler point on the normal by adding the ' scaled normal vector to the point at .5,.5 param. Dim oSamplePoint As Point oSamplePoint = oPoint oSamplePoint.TranslateBy(oNormal) ' Check if the sample point lies on the cylinder axis. ' If it does, we have a hollow face. ' Create a line describing the cylinder axis Dim oAxisLine As Line oAxisLine = ThisApplication.TransientGeometry.CreateLine _ (oCylinder.BasePoint, oCylinder.AxisVector.AsVector) 'Create a line parallel to the axis passing thru the sample point. Dim oSampleLine As Line oSampleLine = ThisApplication.TransientGeometry.CreateLine _ (oSamplePoint, oCylinder.AxisVector.AsVector) If oSampleLine.IsColinearTo(oAxisLine) Then oHLSet.AddItem(oFace) MsgBox("Interior face.", , "iLogic") Else oHLSet2.AddItem(oFace) MsgBox("Exterior face.", , "iLogic") End If Next Next
