ArunS2DHBM
in reply to: Kunal_Bhansali
What will be the code for changing the Design View Representation of the Assembly itself, say View1 to View2, instead of the subassembly.
And also my other rules will work on the design representation. i,e. if I'm in View 1 and running a logic parametric rule to change the size, which has the suppression of some components, whether the same will reflect in View 2 which is not activated.
if not, what should I do, so that it's updated in both the view Representation
Tags (1)
