- Mute
- Permalink
- Report
Export glTF with iLogic
Hello!
I want to export glTF file with iLogic. Now i have script for export obj and want to replace it becouse the files size it 10 time smaller and more. Now i use TranslatorAddIn.
- Mute
- Permalink
- Report
Hi @miroslav.roydev. I have never heard of that file type or file extension before. What specific software generates that type of file? What is it for? What type of Inventor document are you attempting to export as that type of file? I see that file extension listed as one of the ones available for Inventor 2022 exports, but it does not say which software it is associated with, so it is difficult to find which TranslatorAddIn might be associated with exporting that type of file.
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
Hi @WCrihfield, in our company we are making ERP System for our manafucture and in the ERP we want to view the 3D. The software company which we hire to develope the system is using three.js , we made few tests with the different file formant and we have best result with glTF(.glb). Now I want to write iLogic rule which can export all parts in assembly file in different glb files and the assembly.
- Mute
- Permalink
- Report
Hi all, at the end with try and error I succeed to export glTF files.
Dim oApp As Inventor.Application = ThisApplication Dim oDoc As Document = oApp.ActiveDocument Dim oOBJ As TranslatorAddIn For Each oAppAddin As ApplicationAddIn In oApp.ApplicationAddIns ' MsgBox(oAppAddin.AddInType ) If oAppAddin.DisplayName = "Translator: glTF" Then MsgBox(1) oOBJ = oAppAddin End If Next 'The following lines create the needed input variables Dim oTO As TransientObjects = oApp.TransientObjects Dim oContext As TranslationContext = oTO.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oOptions As NameValueMap = oTO.CreateNameValueMap Dim oDataMedium As DataMedium = oTO.CreateDataMedium Dim SavePath As String Dim tDoc As Inventor.Document = ThisDoc.Document SavePath = "\\192.168.2.101\erp\ERP_ROOT\OBJ_3Dmodels\" oBaseName = tDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value oRev = tDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value oRev = FormatRevisionNumber(oRev) oDataMedium.FileName = System.IO.Path.ChangeExtension(SavePath & oBaseName & oRev, ".glb") Try oOBJ.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium) Catch MsgBox(oBaseName) End Try
- Mute
- Permalink
- Report
Glad to see that you got it figured out. ![]()
I do not see that translator add-in available in my list of translator add-ins, which is likely why I could not find the proper one before. I am still using Inventor Professional 2022.2.2 (but getting updated soon), so I'm guessing maybe you have 2023 version installed, because I see that is one of the new translators available in that version (Link1).
Wesley Crihfield
