Michael.Navara
in reply to: RNDinov8r
In this case I recommend you to try iLogic. It is much more powerful then VBA and IO.Path functionality is also available.
Lot of syntax is identical in VBA and iLogic. But if you want to continue using VBA, you can use FileSystemObject
Sub FileSystemObjectTest()
    'With reference to 'Microsoft Scripting Runtime'
    'It enables intelliSense
'    Dim fs As FileSystemObject
'    Set fs = New FileSystemObject
    'Without reference
    Set fs = CreateObject("Scripting.FileSystemObject")
    Dim fileName As String
    fileName = ThisApplication.ActiveDocument.FullFileName
    fileFolder = fs.GetParentFolderName(fileName)
    excelFile = fs.BuildPath(fileFolder, "ExcelFile.xls")
End Sub
